'98 Volvo s70 battery cable corrosion.
dcmatos
Year and Model: s70 1999
Post by dcmatos »
Hello Ladies and Gentlemen,
I have a bit of an issue. I went to replace my battery and a portion of my positive cable broke off. I am a novice when it comes to my Volvo so I would appreciate any advice on what I should do to replace it. I have not connected the battery yet in fear of something else becoming damaged. She's an old gal but she's survived 300,000 miles and counting.
Positive battery terminal
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
One of the best solutions I've seen here on MVS is the universal marine terminal that bob850 shared here:
viewtopic.php?f=1&t=61747&start=50#p443546
Has thanked: 1609 times
Been thanked: 4064 times
Simplest fix is to Dremel or pry off the connector, crimp,three large ring connectors onto each wire separately, then reattach to the same point on the terminal. Some heat shrink to,both insulate and strain relief those connections would be a pro touch.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
For a temp quick fix you can drive a screw through the connector and into the edge of the battery post. Works for days.
dcmatos
Post by dcmatos »
Is it possible to drive without the B+ cable connected? I have a replacement cable but am unable to remove the original. If possible I'd rather take it in than risk damaging it
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Noooooooooooooooooooooo
Ooooooo
(For the ones Jimleft off)
Bad idea
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
^^^I almost got a hernia laughing at the last two comments.^^^
To the OP: Dont do it man. The cheapest longterm fix is going to be those large ring connectors. They are cheaper than dirt at harbor freight.
