OIL LEAK
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
This topic is in the MVS Volvo Repair Database » Big Brakes on Small Wheels
BEMFICA1
OIL LEAK
Post by BEMFICA1 »
My 87 740 GLE is turning 309 K miles. Recently developed an oi leak thru
the engine oil cap (top of the engine). I assume that the pressure inside the engine is too high,forcing the oil out... What should I look for to eliminate the problem? Clogged flame trap,maybe...Car Is running OK.
Also is there a relay controlling the interior lights? Is it located behind the fuse box?
Wud appreciate some help.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2658 times
Been thanked: 1248 times
Post by matthew1 »
Check the cap's gasket. I had to replace mine on my 850.
Also -> Amazon link
Volvord
Post by Volvord »
You both have mentioned the solution, yes clean and/or replace the flame trap, also replace the oil filler cap gasket, this gasket on the B230 engine is a common source for leaks, I replace mine quite often.
http://www.Volvord.com
1998 C70
1989 744TI with a 400HP Ford 302 / 5 speed
