04 XC70 Dash lights
turbotim2
Post by turbotim2 »
I have read through the manual and can't seem to find the fuse for the instrument lights. All other interior lights are working.
2004 XC70
2005 S60 2.5T AWD (gone)
1996 850 GLT Wagon in Blue (gone)
1996 850 GLT Wagon in Green (gone)
turbotim2
Post by turbotim2 »
Anyone have any ideas as to why my dash lights would go out? It is the gauge illumination lights and lcd backlights in the instrument cluster and radio.
2004 XC70
turbotim2
Post by turbotim2 »
I did some more investigating.
* None of the fuses under the hood or in the dash are bad.
* With the car running, the high beams will not stay on, they come on when I pull the lever but won't stay on.
* The headlight switch will not turn off the DRL's when switched to the running lights only position.
* All exterior lights are working.
* Flashers are all working normally.
* The cluster brightness switch does not change anything when moved through it's cycle.
* All of the gauges and warning lights are working normally.
* The radio works but you can not see the display.
* The LCD's for the odometer and clock are working but no back-lighting.
Thank you for any advice!
2004 XC70
turbotim2
Post by turbotim2 »
I am leaning towards possible headlight switch?
2004 XC70
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
turbotim2 wrote: 21 Jan 2018, 09:52 I am leaning towards possible headlight switch?
Did you get any codes?
turbotim2
Post by turbotim2 »
There are no codes. This morning I started it and it was dark. I tapped the headlight switch and got the dash lights to come on but no backlighting. Front and rear fog lights do not work but the fuel door does.
2004 XC70
turbotim2
Post by turbotim2 »
I drove the car again and tapped a little harder on the switch and all of the lights are back on and functioning normally. I suspect a faulty switch or connection. When I get home I will check the connectors on the back of the switch. Does anyone have a quick tutorial on removing the switch?
2004 XC70
Has thanked: 1610 times
Been thanked: 4065 times
You press it out after removing the fuse box panel on the side of the dash if its like my 2005 - pretty sure it is.
Its a snap fit. Just try to do it above -15F for the sake of the plastic
turbotim2
Post by turbotim2 »
Thanks, I got it out last night. Two metal tabs on the top of the switch and one on the bottom. Pretty easy.
2004 XC70
turbotim2
Post by turbotim2 »
It was a bad switch. Put a new (used) one in and it's all better.
2004 XC70
