2006 2.5T coolant leak question
AnotherPassword
Year and Model: 2006 XC90
Post by AnotherPassword »
Hi All,
Strange thing. I replaced radiator a few days ago because it had a pinhole leak. Wife drove it a few days, and I started getting a pretty good amount of coolant coming from the cover on bottom of engine. My thinking is that since it was not fully perssurizing, maybe the radiator fix fully pressurized the system and now a new leak? Not leaking around radiator or any of the hoses I worked on, and did not undo any hoses on engine side. Did not replace thermostat housing etc.
Took cover off bottom of engine, it seems to be dripping down oil filter area and drops on bottom of cover at bottom of balancer. Thought maybe water pump, pulled plastic cover. Pic of water pump, seems a little dirty but not leaking. Leak seems to be dripping around the bracket that holds the a/c compressor, so probably from above it? Would that be the thermostat housing? I don't see any coolatd, kinda hard to see in there, and it has been really humid here so not sure.
Am thinking that while I have it torn down might as well do the timing belt and water pump kit. When I bought it Carfax said it had been replace, but I have 130k miles on it and no sticker under hood showing timing belt service.
I am not positive it is the water pump given where the drips are, so had to just do water pump and still have a leak.
Thoughts?
thanks,
ds
Rattnalle
Year and Model: 2004 V70 2.5T
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
Isn't the oil filter pretty much right under the thermostat and it's hoses? Including hoses for coolant through the pcv if you have that kind.
AnotherPassword
Yeah, I am kinda leaning that way and going to do the thermostat housing. Any thoughts on the timing belt? It does not look real worn.
Rattnalle
Post by Rattnalle »
I replaced mine this autumn at 150 000 km and 7-8 years and it didn't look worn either. The pulleys do look very clean though compared to mine. The red bearing seal in one of your pictures for example.
In Sweden the practice is for Volvo to replace the water pump only every second timing belt unless it feels bad in some way. Yours doesn't look like it's been changed but it also looks dry and not leaky.
Stuff some paper or rags around the thermostat hoses and see if they get wet.
blandis
Year and Model: 99 S70 T5
Been thanked: 3 times
Post by blandis »
No leak prior to work on the radiator... I would retrace my steps. Start up high with paper towels and work your way down until they are wet would be my approach. Any chance you pulled a bolt from block that requires a bit of sealant? Not even sure if this is a possibility and if so which bolt require sealant. Just a guess as I am unsure of what all was taken off to get radiator in and out.
I have same setup. I did water pump, tensioner, belt and all while I had it apart at 100K. Belt looked fine as did water pump. I knew I would not keep the car until 210K when next belt change was required. My approach is do it all while it was apart and not have to worry about tearing into it again for another 100K plus for any reason. Never had a WP leak on any of the various 5 cyl cars I have owned. Ran my T5 s70 225K before I changed the WP and it was fine.
Brad
Nashua, NH
2017 XC60 AWD
2006 XC90 2.5T
AnotherPassword
Dang, good idea on the paper towels in and around tstat, I will give that a shot. Also, on the tstat housing, the other suspect is the hose that comes off of the tstat housing an goes under the intake. Looks like it connects to a metal tube and that and a wire are in a sleeve that I can't see where it goes. Is there a diagram that shows where all the coolant hoses go? I have not seen that one coming off the tstat in any pics.
On tstat housing assembly, I see everything from OEM to Dorman, is there one that is more recommended than others?
Thanks again for all the input.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Careful with the paper towels not to get trapped into the spinning belt. I woukd guess the hose to the thermostat is not tight or doesn't seal properly. The water pump seems to be stamped Volvo so should be good up to 200k miles. The belt looks recent but double check for cracks on the other face of the belt. Thermostat don't touch dorman, use Beck & Arnley or Volvo
Roger_850T
Year and Model: 854T 1995
Been thanked: 26 times
Post by Roger_850T »
If you can, it's sometimes helpful to pressurize the system cold to help track down leaks. I have a little hose section that has a Schrader valve and a gauge, and I put it in the line by the coolant reservoir, then pressurize to ~10psi or so with compressed air. When it's hot, the coolant can come out as vapor and be tough to find, but when it's cold you can see it dripping easier. Plus, you're doing it when the engine is not running, which means you don't have to worry about getting caught in moving parts...
Roger
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
rakesh4404
Year and Model: 2005 XC90
Has thanked: 5 times
Post by rakesh4404 »
I have the same problem, after recent radiator job the leak from the radiator stopped but right under the Engine/oil filter the Coolant is leaking. Not sure if I snapped something during my work.
Any guidance will be helpful.
leatherntextilec70
Year and Model: Volvo 1999 c70
Has thanked: 1 time
Post by leatherntextilec70 »
I recently noticed the EXACT same leak on my 5 cylinder after taking care of all the other leaks. From below it looks like its coming from between the ac bracket and oil pan and leaks down the filter and pan the same way as your pictures. I have been looking at the car for days trying to find the source, looking with a flashlight at all angles and even breaking out the digital inspection camera. On the second try with the inspection camera I finally saw a drip of coolant forming on the under side of the thermostat housing. Looking from above I can see the side of the thermostat housing (aluminum piece that goes from thermostat cover to cylinder head) is wet and coming from the thermostat cover. Very difficult to see at first since its all shades of grey with little visibility but I am certain this is the source, at least on my car. Likely the o ring for the thermostat is bad, or the thermostat cover is warped.
