I think my 95 2.4L is burning oil faster than it should be. Maybe 1qt/1000 miles. I've never gotten an answer as to what the tolerance is before it's time for an overhaul. For example 1qt/1000 miles is acceptable oil consumption in a 350 chevy. Greater than that it's time for an overhaul.
What should I be looking for in this 2.4l engine?
Compression test?
Leak down test?
My exhaust is pretty clear, no blue puffs at startup like my old car. I'm wondering if my rings arent going.
Any thoughts are invited.
What is "normal" oil consumption? Topic is solved
- callahanoffroad
- Year and Model: 1995 850
- Has thanked: 16 times
- Been thanked: 53 times
Author, Chef, and Shade Tree Mechanic
1995 Volvo 850, Non-Turbo, VVIS, LH FI, Green, 215,000 miles. B5254FS engine. Herman. viewtopic.php?f=1&t=84393
1996 Volvo 850, died at 280,000
Founder of: CookingForChemo.Org
Read my Silly Comic Book at: therealpizzabros.com/
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Factory says that 1l/1000km is the upper limit of oil consumption.
Depends of oil viscosity.
These cars burns oil from factory....mine was burning 1l/10k km from new.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 1613 times
- Been thanked: 4075 times
Another topic along the lines of " What is the true religion" and "Who put the hole in June's upholstrey?" that can only lead to the darkness of the internet...
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
I'd say normal is at most a litre per service interval. And that's 15000 km. Mine didn't take that much at almost 350' km.
Those upper limits are just a liability thing. They're not normal.
- June
- Has thanked: 523 times
- Been thanked: 261 times
Mike put the hole in june's seat! Juneabscate wrote: 11 Apr 2018, 12:14 Another topic along the lines of " What is the true religion" and "Who put the hole in June's upholstrey?" that can only lead to the darkness of the internet...
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
What oil are you running? 1 qt/1000 miles is a bit high. If I were you, I'd try sometime like Mobil 1 10W-40 High Mileage and see if anything changes.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
The crankcase vent system needing to be serviced can cause high consumption, especially if the drain passage in block to below oil level in pan is plugged. That keeps the condensed oil from vent box from going "home" and that oil then goes through the intake and is burned. I don't recall seeing an 850 smoke from that. Are the spark plugs very heavily deposited if you inspect them?
- FLXC90
- Year and Model: 98 V70 T5
- Been thanked: 45 times
+1 to what Jimmy says.
Wet vs dry compression test ( for science!)
Run some ATP AT-205 through your oil to re-invigorate your valve stem seals (and many others).
replace oil cap seal.
Current Volvos:
- callahanoffroad
It's obviously volvoism, not volvology.abscate wrote: 11 Apr 2018, 12:14 Another topic along the lines of " What is the true religion" and "Who put the hole in June's upholstrey?" that can only lead to the darkness of the internet...
I knew this was a dark hole. But sometimes you gotta open it!
Thanks for the responses.
1L/1000km is an easy measurement to remember. Thanks Misha!
- SuperHerman
- Been thanked: 207 times
Hocus Pocus. The car should not burn more than 1/2 quart every 3000 miles under normal conditions. The rest is just an excuse for something wrong. Every Volvo I have owned never burned more than 1/2 per oil change, one was at 190k miles. If the oil consumption is up then something is wrong or the engine is old and tired. At this point the question is what are you willing to accept.
My old BMW and Porsche at highway speeds a different story.
