Hi
Its been a month since i bought a 850. The car has given me no serious problems at all. But there are 2 little details that been annoying me
When i roll the driver's window all the way down i get a strange clanking noise and the power antenna isnt working
Thanks
A month with a 850, all the issues so far
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
I try to not roll the window all the way down.Nico99 wrote: 24 Apr 2018, 12:37 Hi
Thanks
Knows enough to be dangerous
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
Most probably the rear window guide in the door is broken. Take the door panel off (good videos can be found on how to do that). Tgen check for loose parts inside the door. Replace if necessary.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
sventastic
- Year and Model: 1996 854R
- Been thanked: 6 times
I have the same clunk when rolling the window all the way down and have been told this part is the culprit
https://www.fcpeuro.com/products/saab-w ... tor-roller
1996 854R | M56H | 16T | 274k | BC, Canada
- June
- Has thanked: 523 times
- Been thanked: 261 times
It seems to me I recall when the antenna went bad in I think the 1996 960 Volvo put a new mast in it. I had a couple power antennas go bad over the years. I was so happy when Volvo did away with them. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
Nico99
- Year and Model: 1995 850 GLT
- Has thanked: 3 times
Im trying not to do that but its tricky because of the auto switchWhatAmIDoing wrote: 24 Apr 2018, 13:32I try to not roll the window all the way down.Nico99 wrote: 24 Apr 2018, 12:37 Hi
ThanksPower antenna not working is extremely common, mines up so I don't care. There are a couple threads detailing how to replace or rebuild the power antenna motor if you search.
Nico
Nico99
Well now that ive taken out the door panel, I see youre right the guide is completely loose but not broken. Is there any way to fix it ?Clemens wrote: 24 Apr 2018, 14:11 Most probably the rear window guide in the door is broken. Take the door panel off (good videos can be found on how to do that). Tgen check for loose parts inside the door. Replace if necessary.
Nico
- Has thanked: 311 times
- Been thanked: 817 times
Check the end of the guide where it attaches to the door - that is where they usually break. Even though it looks good it may be broken.
- Has thanked: 2200 times
There should be a torx or phillips screw about halfway down the back edge of the door below the latch. If it is there, remove it and you will probably find the bracket that should hold the window rear guide has broken and falls into the bottom of the door. Later cars used a rivet to hold it in place. The 850 one may be obsolete but the later V/S 70 one works too.
- 729 Views
Last post by Kyle123
- 14 Replies
- 3747 Views
Last post by precopster
- 1201 Views
- 12 Replies
- 2534 Views
Last post by scottinalaska
- 3678 Views
Last post by RickHaleParker
