1998 V70 GLT Help Hard Crank
Flashwook
Year and Model: 1998 V70, 2000V70R
Post by Flashwook »
I bought this car about a year ago as an experiment. It started long cranking about 3 months ago. It has never not started but wont start without multiple on/off and pressing the gas pedal or pumping. It has had the fuel pump, filter, pressure regulator and the fuel controller relay all replaced. It has also had the fuel injectors cleaned. Im not sure what else to do with it. Thanks
Has thanked: 294 times
Been thanked: 767 times
Post by erikv11 »
I am guessing it is probably the ECT sensor: https://www.fcpeuro.com/products/volvo- ... wf-9186486.
You can first check carefully the connector on the existing ECT for rotten wires and/or a corroded connection, sometimes cleaning that up will fix it. Or you can pull the ECT and check resistance at different temperatures. Or roll the dice and put a new one in. Does the temp gauge on the dash run at a solid 3 o'clock position when the car is all warmed up?
Do not put in the 15$ version, like this one: https://www.fcpeuro.com/products/volvo- ... -9186486-1. It will go bad very quickly.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Flashwook
Post by Flashwook »
Yes runs great once started and straight at 3 once warmed up.
Flashwook
Post by Flashwook »
I have 5 P80 cars so I just pulled one from another car and Ill try it tomorrow.
surfbug1
Year and Model: 1998 V70, 2006 S80
Has thanked: 41 times
Been thanked: 9 times
Post by surfbug1 »
Late reply.....what was the result?
Didja fix it? How, if I may ask?
Al
Got a C3 Corvette corvette for sale? 1968 to 1981...not the 1982 crossfire injection
Ping me!
:D
Has thanked: 1511 times
Been thanked: 3827 times
surfbug1 wrote: 29 Jul 2022, 15:22 Late reply.....what was the result?
Al
We have built empires in that four years, with the cunning use of flags….
surfbug1
Post by surfbug1 »
abscate wrote: 29 Jul 2022, 15:50
Al
Hahaha True that sir!
Always like to hear the fix, so I was reaching on this one!
Ping me!
:D
