All,
I have just replaced both front indicator/running lights on my 03 S60 T5. The lights come on, but will not flash, after replacement. Getting a fast clicking in the cabin when using turn signals.
Passenger side was out, and driver side was working fine, but i replaced both.
Anyone have any ideas
Turn Signal Issues 03 S60 T5
All other marker lights are working. installed Sylvania 1157A bulb, and the bulbs i removed were marked with 1157A.
Should i try getting replacement sockets at this point?
- MDK
- Year and Model: 2004 S60R
- Been thanked: 42 times
I've had this happen before... It seems that there is still a bad bulb somewhere. It's tough to check by yourself
I usually back up to a window and look to see all the rear taillights are working as they should. I personally don't have much trouble with Volvo's wiring harness's... although I had to replace the board that holds the rear bulbs in place on my 2004 S60 R car
Check for voltage first
- 1322 Views
Last post by MDK
- 544 Views
Last post by Sveedy
- 2689 Views
Last post by MDK
- 1080 Views
Last post by Georgeandkira
- 341 Views
Last post by duckpond
