The key just turns the cylinder round and round. Doesn't engage the door lock. I took the panel off and see that the linkage to the lock cylinder was not attached, but couldn't figure out how to re-attach it. It's a small area mostly covered by the sheet metal of the door. Very hard to access.
Anyone know how to do this?
Thank you.
Key Doesn't Open Driver's Door
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
Look at this, might be same as yours.Wagon99 wrote: 13 May 2018, 11:15 The key just turns the cylinder round and round. Doesn't engage the door lock. I took the panel off and see that the linkage to the lock cylinder was not attached, but couldn't figure out how to re-attach it. It's a small area mostly covered by the sheet metal of the door. Very hard to access.
Thank you.
- MDK
- Year and Model: 2004 S60R
- Been thanked: 42 times
Yeah .. hey there Jones g...my key cylinder on the driver's door needed to be replaced... I went to scrapyard and replaced the entire Assy for door ( S70 or v70 same cel central locking system...1key door and another for everything else...get key with lock from salvage just plug in ... no software involved
- jonesg
A good junkyard is Disneyland for bros.!MDK wrote: 13 May 2018, 15:24 Yeah .. hey there Jones g...my key cylinder on the driver's door needed to be replaced... I went to scrapyard and replaced the entire Assy for door ( S70 or v70 same cel central locking system...1key door and another for everything else...get key with lock from salvage just plug in ... no software involved
Wagon99
- Year and Model: 2002 V70
The cylinder is not the problem. The cylinder is fine. Problem is, the lock housing is not connected to the door lock.MDK wrote: 13 May 2018, 15:24 Yeah .. hey there Jones g...my key cylinder on the driver's door needed to be replaced... I went to scrapyard and replaced the entire Assy for door ( S70 or v70 same cel central locking system...1key door and another for everything else...get key with lock from salvage just plug in ... no software involved
- jonesg
Have you unbolted the lock barrel and withdrawn it from the door?Wagon99 wrote: 13 May 2018, 19:59The cylinder is not the problem. The cylinder is fine. Problem is, the lock housing is not connected to the door lock.MDK wrote: 13 May 2018, 15:24 Yeah .. hey there Jones g...my key cylinder on the driver's door needed to be replaced... I went to scrapyard and replaced the entire Assy for door ( S70 or v70 same cel central locking system...1key door and another for everything else...get key with lock from salvage just plug in ... no software involved
