alumnium heatercore pipes rusty
loveMy850
- Year and Model: 1994 850 WAGON
- Has thanked: 97 times
- Been thanked: 4 times
Hi guys, Hope everyone is having a Great Day! I went to the Junkyard and found my alumnium heatercore pipes for my "94" 850. they are rusty. what is the best and safest way to clean the rust off where the orings fit on. I've thought steel wool but afraid of scratching them, fine sandpaper is what most people recommend, Whats your take? I want the orings to fit perfectly, I dont want any leaks, This is a pain in the rear job........
loveMy850
I want to apologize to all who responded to my post and I did not return any questions nor answers, for awhile I could not get my password to work, and I'll admit I have'nt had the time.The sputtering has gone away, I had my cat. converter checked.it was fine and afterwards I replaced my fuel pump relay, walla!! but then it happened again, I replaced the fuel filter then put in a new fuel pump, the minute I reved it a couple chunks of old cat. converter rock came out, since then its been fine, ever now and then I think there are a few that keep coming out of the muffler,kinda weird I know, but hey shes all good. except the heatercore rust, I see I have views but no replys, Like I say it was'nt my intention to shine anyone one, Sorry! Have a Good Day!
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
If it were me, I'd replace them.
2023 Lexus RZ450e -66k
precopster
- Year and Model: Lots
- Been thanked: 128 times
Trouble with replacing them is the firewall coupler will probably start to leak once they are released necessitating even more cost & labour.
Many have cut the tubes shorter to avoid using the coupler and run standard heater hose through a gutted out coupler straight to the engine block.
loveMy850
I replaced the coupler with a new one took some time let me tell ya. I'm taking a break are will clean up the pipes I've ordered and got all new prongs. It should be ok. I'm going with fine sandpaper. Thanks
- Has thanked: 1611 times
- Been thanked: 4072 times
The only place that matters is where the orings sit, for sealing. Fine steel wool might scratch a bit but the oring would seal on scratches fine.
- 4408 Views
Last post by 93Regina
- 1764 Views
Last post by oragex
- 718 Views
Last post by voom8
- 2362 Views
Last post by seanj
- 23 Replies
- 6370 Views
Last post by Phantomphixer
