2000 volvo s80 2.9L
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
Ttwerie
Year and Model: 2000 volvo s80 2.9L
2000 volvo s80 2.9L
Post by Ttwerie »
Any ideas appreciated
I have a 2000 volvo s80 2.9 L
Was driving to work today and after driving for a while was stopped in traffic. When i eventually accelerated again i observed the abs light along with the brake light and traction control light come on at same time. Also a message read brake failure stop safely asap. Car was still running fine but also noticed no speedometer or tachometer or oil temp but i made it to work. After shutting off when I went to restart it started for split second and stalled and after that it will turnover strong but will not start. If i let sit for awhile once again wil start for split second and again not start with both battery and alternator fairly new and tested voltage is good on both
Thanks in advance!!!
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2658 times
Been thanked: 1248 times
Post by matthew1 »
Did you check for codes?
Also -> Amazon link
Ttwerie
Post by Ttwerie »
P0011 code came up before attepting to restart car 8 hours later and code cleared after seeing one time
Ttwerie
Post by Ttwerie »
Also now will turnover strong but wont start.
Thank you in advance
matthew1
Site Admin
Post by matthew1 »
Also -> Amazon link
Ttwerie
Post by Ttwerie »
Thanks for the links
Have to examine in daylight closer. I suspect it did advance a tooth, hopefully tensionsr. All signs point to that or cam shaft sensor (note small oil leak may of lead to this) or it seems the solenoid which i am not even aware of it also points to 🤔
