Hi folks, I've read as many posts on the v70 power windows I could find but nothing relating to my issue.
Both rear windows are stuck open about an inch. (It's cold and snowy where I live).
Neither the drivers master switch will put them up, nor the individual switches on the door.
There IS a clicking from under the dash when I try to activate the switch from the drivers seat.
Fuse is fine. Front ones both work as they should.
Could there be a child lock relay I should be looking for?
Thanks in advance. Second elusive issue to be posted shortly.
Power window issue (rear-both) 01v70 non turbo.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
On your drivers buttons you have the rear windows lock switch. Maybe this switch has an issue and it's completely locking the windows. Try playing with it a little
Maybe also inspect the rear electronic module (REM) fuse, not sure if the windows are on this module
Hi, thanks for this; the REM fuse checks out ok as it's also for the cargo light.
Did some serious wiggling of the switch, while manipulating the window control buttons, no change- just the clicking (sounds like from under the dash)- same thing when working the rear window buttons. stumped!
- oragex
Perhaps try the door child lock switch? Its in the door frame
- 2079 Views
Last post by lcc014
- 12 Replies
- 2893 Views
Last post by Sufbug
- 2113 Views
- 1177 Views
Last post by theWIFES_S70
- 637 Views
Last post by xiaofei204716
