Hi,
I noticed sometimes that when I am driving and press the brake, a few things happen. If I have the radio on, it turns off and then back on when released. If I have one of the reading lights on, it dims. The SRS light flashes sometimes for a split second.
In addition, the following has happened maybe 5 times over the past month. when I go to start the car, the dash lamps illuminate, but nothing turns over or clicks. I wait about 5 seconds, and then it starts up as it should.
Lastly, I just went to turn on the radio today and it is asking for the original 4 digit code.
Something must be interlinked with these systems which is causing these things to happen and any help would be appreciated.
Thanks!!
1996 850R Electrical Issue?
- Year and Model: Many Volvos
- Been thanked: 76 times
The electrical portion of the ignition switch comes immediately to mind.
- Been thanked: 4064 times
You are getting a break in primary power to things, so the ignition switch and wiring all the way to the battery are suspect
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
This... Start with the basics of your heavy cablingabscate wrote: 21 Dec 2018, 15:50 You are getting a break in primary power to things, so the ignition switch and wiring all the way to the battery are suspect
and connections from battery, alternator and B+ to
the main fuse box. All of the big primary grounds, as well.
