REPLACING BULB
- Year and Model: Many Volvos
- Been thanked: 76 times
While I don't know a thing about V-70 XC's Here is the VADIS procedure.
Looks like quite the job for a light bulb.
Hope it helps,
Hope it helps,
It appears from the procedure that the entire headlight assembly must be removed to gain access to the bulb. The two pages from VADIS, which is the computerized factory service manual, describe how to remove the headlight assembly.
I shudder to think what the dealer would charge to replace the $2.00 light bulbs.
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
The following is the instruction in the Volvo owner's manual:The message panel says that the front turn signal is out (passenger side).
Changing the bulb in the turn signals at the front corners
Switch off all lights and turn ignition key to position 0.
Pull out the bulb and its socket by twisting counterclockwise. Replace bulb.
Press the bulb and its socket back into place.
Check that the new bulb lights.
If the washer reservoir is in the way then it will need to be removed. I had to do this on my 740 to replace some of the bulbs.
Go to http://www.volvocars.us/tools/OwnersInfo/ register and download a copy of the manual from the Owner's Library FOC.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
Volgrrr
- Year and Model: '95 T5 wagon
Bill,
I tried to download a copy of the owner's manual from that site, but it looks like access the site can is only permitted if you have an American address.
There are only two types of car owners - those who own Volvos and those who wish they did.
- Has thanked: 17 times
- Been thanked: 35 times
Did you try this link for the download?
https://www.matthewsvolvosite.com/downlo ... vo_850.zip
- 4881 Views
Last post by adrian22
- 4146 Views
Last post by silentcircuit
- 2642 Views
Last post by firstv70volvo
- 3258 Views
Last post by mikeamondo
- 4405 Views
Last post by wizechatmgr
