2004 XC90 2.9 Rear End Issue
xyourobob
- Year and Model: 2004 XC90, 2011 XC60
- Been thanked: 4 times
My 2004 XC90 2.9 started making a weird screeching/grinding noise and it sounds like it is coming from the drivers side rear. I jacked up the rear of the car and the drivers side rear tire does not spin freely however the passenger side does spin freely and I'm wondering if this is normal? I took the wheel off on the side that I think the noise is coming from, I removed the caliper and the wheel still does not spin freely. The vehicle has about 230K miles and I have replaced the rear wheel hubs once or twice in the past but the symptom was always a loud humming from the wheel which I'm not getting now. These hubs have lasted longer the prior hubs and I'm wondering if their was a new design on these hubs and the symptoms have changed when they are at the end of their life? I'm hoping it's not the rear end...
Masscomguru
- Year and Model: 2010 XC90 V8
- Been thanked: 16 times
I would pull the disc off and see if the parking brake shoes have delaminated. This has been known to happen with age on these.
xyourobob
My rear wheel hub was seized. I broke the center wheel hub off in the axle because I must have gotten wrong info on torque. In any event how does the rear axle come out of the rear differential? And what is the correct torque for the center hub bolt?
- ggleavitt
- Year and Model: 06,08 XC90 V8
- Has thanked: 26 times
- Been thanked: 134 times
Been there, done that. Snapped the bolt off on my first bearing replacement, torque value for rear is not straight forward and I was heading towards 105Nm with a "am I sure this value is right?" just before the nut and washer popped off. EasyOut thankfully got me back on the road as well.
Value for rear I believe is mismarked in VIDA as- "Brake caliper rear in wheel bearing housing XC90 (M10) " with Step1: 35Nm then Step2: angle tighten 60 degrees.
Front is correctly indicated as- Drive shaft in front wheel hub, only XC90 (M10) Step1: 35 Nm then Step2: angle tighten 120 degrees (Step2 is 60 degrees if car is not XC90).
These are torque to yield (controlled deformation) hardware, as such they should not be re-used. Even with the spec torque values, I can feel the bolt "stretch" as it gets tightened.
Good luck with your repair.
- 15 Replies
- 4439 Views
Last post by wizechatmgr
- 14 Replies
- 4277 Views
Last post by NathansC70
- 1201 Views
- 13 Replies
- 3984 Views
Last post by xyourobob
- 386 Views
Last post by dualcitizendisorder
