Broken door latch
dgt5264
Year and Model: 2000 V70
Post by dgt5264 »
I can not open the drivers door from either inside or out need suggestions on how to get the door open it is not locked something has broke within latch. Can't remove door panel until door is open,
Thank you
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Before you start ripping it apart try these.
With one hand pull up and hold up the door lock. With the other hand pull the latch.
Push in and hold in the door, and pull the latch.
Try these from both inside and outside.
Active
Past
dgt5264
Post by dgt5264 »
thank you for your prompt reply but its back to the drawing board.
