Hello everyone,
I recently acquired a 2001 Volvo S80 that I've begun working on over the past year: replacing the radiator, A/C blower, fuel flap actuator, and some other minor parts.
In the past three days, a new problem arose: when I turn the key into the third position, initially there are no clicks for about 5 seconds, then a very slow turn-over as the car starts. Momentarily the dash lights with dim as the car turns over.
I haven't been able to find any topic on this forum or elsewhere where there's initially no click and an eventually turn-over.
I check the starter wire for any corrosion (none), as well as the battery hook-ups for loose fittings or corrosion (none).
Thank you for your time.
Slow Start, Initially No Clicks
- RickHaleParker
- Been thanked: 978 times
Start with the battery.
1. Make sure the battery terminals are clean.
2. Make sure the battery it not defective and fully charged.
Active
Past
Past
Hello,
Thank you, Rick.
Battery terminals are clean. Multimeter read 12V before starting the car, then jumped to over 13V, so the battery seems fine.
This afternoon, the car started three times without a problem.
Thank you, Rick.
- 8298 Views
Last post by Oka
- 1753 Views
Last post by jpac
- 1386 Views
Last post by AKJeeper
- 1093 Views
Last post by June
- 539 Views
Last post by readallthebooks
