Door Water Leak
CEBirnley
- Year and Model: 1998 V70 Base FWD
- Has thanked: 13 times
Door Water Leak
The wind caught my driver side door and ripped it from my hands. Now, when driving down the road, I can hear the wind entering the vehicle as well as when it rains, water enters. This is occurring from the top of the driver window, area, basically where the door meets the roof line. I can stop the wind/water from entering the vehicle by pulling the door tightly right where the door/window curve Any thoughts? Fwiw, The mechanism which holds the door from swinging all the way open actually broke so I will be in the process of replacing that. gotta love the wind in Nebraska!!
- Has thanked: 1848 times
- Been thanked: 1710 times
Check the hinges are not bent or the A pillar. It could be they have been slightly deformed or bent with the hard stop.
If you can pull the door in to stop the noise it would point toward something is loose in the hinge mechanism.
Check the top area of the door has not bent (above the glass line). If the door deflected a bit, try opening the window fully and bend the front of the door frame/top of the door slightly inward.
- Has thanked: 1505 times
- Been thanked: 3818 times
You need to replace the front fender if the hinges bent
I did mine in a snow bank,
- callahanoffroad
- Year and Model: 1995 850
- Has thanked: 16 times
- Been thanked: 52 times
I hear that great stuff foam works well for sealing....
Author, Chef, and Shade Tree Mechanic
1995 Volvo 850, Non-Turbo, VVIS, LH FI, Green, 215,000 miles. B5254FS engine. Herman. viewtopic.php?f=1&t=84393
1996 Volvo 850, died at 280,000
Founder of: CookingForChemo.Org
Read my Silly Comic Book at: therealpizzabros.com/
tardcart
- Year and Model: 96 850t. 93 940t
- Has thanked: 3 times
- Been thanked: 37 times
I cant even imagine living where the wind could bend a volvo door. How do you keep the doors on your house? I remember doing a job three days in 30mph wind and I almost went crazy.
