Car shakes Topic is solved
Hey guys, for the past couple of weeks my car has been shaking when I accelerate. It is very bad when going around a curve turning to the left, and if I have a passenger it gets worse. I have gotten my tires changed and balanced and that did not fix it. Does anybody have any idea what is causing this?
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 79 times
- Been thanked: 71 times
Miles on your vehicle, please.
Drive next to a wall and listen for bad CV joint(s)-clicking.
Could be an engine mount?
Maybe wheel hop exacerbated by shot front struts?
- prwood
- Year and Model: 2001 V70 2.4T
- Has thanked: 9 times
- Been thanked: 22 times
CV joints and engine mounts, like Georgeandkira said, are my two guesses. I have dealt with shaking during acceleration in my '01 V70 twice; the first time it was due to a worn right inner CV joint and the effect was really bad, it shook everyone and everything in the car. The second time was due to a bad right motor mount. In that case it was more of a vibration and growling, not as severe but still a bother.
Cars I've owned:
- 2015 to current: 2001 Volvo V70 2.4T; 2004 Honda Odyssey
- 2007 to 2015: 2002 Subaru Legacy L Wagon
- 2003 to 2016: 2001 Toyota Corolla LE
- 1999 to 2003: 1994 Toyota Camry LE
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Seafoam withdrawal?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Shake upon acceleration may also be worn control arm bushings. Easy check www.youtube.com/watch?v=P1QaJbyjr2s
Either are old, either been replaced with some cheapies. Recommended brands Lemforder, Genuine and perhaps IPD HD - off sites like Fcpeuro or Ipdusa
It has 276k on it, and it's doesn't really click when turning except for a single pop when turning all the way leftGeorgeandkira wrote: 03 Jun 2019, 14:00 Miles on your vehicle, please.
- oragex
That pop is the steering limiter, plastic piece on the control arm. See how worn it is an put some grease on it. You'll need to swap it if replacing the arm
- Been thanked: 4064 times
That’s probably it. You can’t just get a boot kit and clean out the joint, repack with grease , and pit OTT back in
Drive shaft will have to come off though.
- prwood
Did it look anything like this?dpayne20 wrote: 03 Jun 2019, 19:56 I think it is the inner cv joint on the front passenger side. I looked and the inner boot is totally ripped and there is a good bit of play
[youtube][/youtube]
That's what mine looked/sounded like. You can try repacking the joint and replacing the boot, but you may end up needing to replace the axle as I did.
Cars I've owned:
- 2469 Views
Last post by Clemens
- 2072 Views
Last post by volvolugnut
- 11 Replies
- 1964 Views
Last post by ashitaka695
- 750 Views
Last post by sek
- 1154 Views
Last post by oragex
