I thought I did a poor job and had to do it again. So about 2 months ago I removed it for the second time and the plug inside was again full of brake fluid. No leaks abound it, no leaks from ABS pump just inside the big connector. Cleaned it but it didnt work.
Now got the module out again, same fluid inside the plug, very little inside the module around the plug areal like a drop or two. All around the brake pump is dry, not a drop or sweat, dry like a desert. Im going to work on the logic board again to see if there's any more faults but my question is where is this brake fluid coming from?
List of errors and picture where the fluid is collecting:
