The typical yellow arrow flashing problem and it’s causes
Along with flashing arrow also winter , econo and sport light flashes as well. Winter mode same
As flashing arrow lymp mode or 2nd gear take off. At one time i seen a code for wrong gear from the obd codes.. Somewhere I read key on and off with rapid selector movement to remind module what gear it was in and that worked for awhile. To clear up the limp mode problem. Car will take off in first again. But now the error is more persistence to go away. I heard module on trans gets dirty and causes problems like this.
Sweden built car
Any helpful thoughts. ???? Just to many diff problems for one yellow arrow to have and sort out
1995 850 turbo transmission problems.
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Well the most common cause is a dirty PNP switch. Rowing the shifter back and forth helps clean it up and it sounds like you did that and had some initial success. Based on that I would recommend removing the PNP switch and cleaning up the insides and then reinstalling it.
Here's a long winded write up on the removal, cleaning, and reassembly of the PNP switch: viewtopic.php?t=29930
And Robert has a video of the process here:
I don't think you mentioned what year your 850 is but if its a 95 or earlier then you can read the transmission codes and get a better idea of what the problem is. If it is a 96 or later you'll have to have the codes read at a Volvo dealer or repair shop.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
With flashing arrow car take off in 3rd gear.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 3206 Views
- 931 Views
Last post by Kokonradus
- 1249 Views
Last post by 93Regina
- 2479 Views
Last post by tryingbe
- 852 Views
Last post by ErickKW
