transmission fluid flush
Tomca_
Post by Tomca_ »
Hello Everybody,
I have a 1990 Volvo 740 GL, with manual 5 speed transmission (I think it is MK 47 II). I want to buy transmission fluid to it. I have a book about Volvos and it says that I need ATF Type F or ATF Type G fluid, but I simply cannot find these types in the shop. I can see ATF II, ATF III, ATF DEXRON, SAE types, but not ATF F or G. Is there an equivalent from these?
Tamas
ToeCutter66
Post by ToeCutter66 »
The general consensus is that these transmissions work best and last longer with a good synthetic gear lube. Look for RedLine MTL or Amsoil Synthetic gear lube.
Kevin
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Type F/G was made specifically for early Ford auto boxes but was picked up by other manufacturers and specified for their vehicles.
The following companies still produce Type F/G fluid:
Chevron/Havoline; Shell; Mobil and Valvoline.
If you go for Redline or Amsoil then you need their Synthetic Racing Oil as it has the properties of Type F.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Tomca_
Post by Tomca_ »
Hello Everybody,
thank you for the advices. I could by Valvoline type FA, which is compatible with type F.
