I had to replace a windshield washer nozzle on my '97 855 GLT (222k miles) because one of the locking tabs broke off, allowing the nozzle to pop out of the hole.
Can you guess which nozzle is OEM and which one is a $4 aftermarket part?
Low mag:
Nozzle A:
Nozzle B:
Higher mag:
Nozzle A:
Nozzle B:
Spot the 'impostor': windshield washer nozzles OEM v aftermarket identification
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
They both look surprisingly crappy, but I'll go with B as the OEM.
1999 V70 GLT
1999 V70 GLT
- jreed
I'll let others guess too for a short while. Nozzle B was the one that broke after having been on the car for about 10 years -- that's why it looks a little beat up.
- June
- Has thanked: 523 times
- Been thanked: 261 times
Nozzle B is Genuine Volvo. Nozzle A is too narrow to provide the wide spray pattern original Volvo nozzles do. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- jreed
June, Sveedy, you are both correct.
Here is what Nozzle A and B look like while spraying.
Nozzle A is on the left shooting out a fairly narrow stream, and Nozzle B is on the right spraying a wide pattern. I guess I'll give the new Pro Parts Sweden (Nozzle A, left) a try for a while to see if it's good enough, or if I have to spring for a new OEM Volvo nozzle. The part number on the Volvo nozzle is 30655605. It is marked POM. The new Pro Parts nozzle is marked PA-66.
- June
If you use them as often as I do, i predict you will be buying Volvo replacements. June
My Volvo cars owned
1996 960 ordered
1996 960 ordered
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Neither of those two looks like mine.
Mine are still original.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 311 times
- Been thanked: 817 times
I have put 98-00 x70 nozzles on all of my 850s. Much nicer, broader spray pattern. Mine all came from the junkyard but if you're buying new, I'd get those over the 850 ones. Unless they are all the same now, which is possible.
- Has thanked: 2203 times
If I recall I used P2 nozzles (I may be wrong) as the mechanics at the dealer when worked there for a few months said they were much better than P80 versions.
- Sveedy
If I were to go and take a pic of my windshield washer sprayer, would I then qualify as a volvophile ?
1999 V70 GLT
1999 V70 GLT
- 804 Views
- 15 Replies
- 8749 Views
Last post by volvolugnut
- 36 Replies
- 24751 Views
Last post by StickyPocket
- 529 Views
Last post by ZionXIX
- 4463 Views
Last post by eyerollXC70
