RPM drop by 200 to 300 while decelerating
Tarek80
Year and Model: 2001 c70 conv
Has thanked: 1 time
Post by Tarek80 »
Hello,
First of all, let me thank you all for all the useful information. I have learnt a lot :)
I have a 2001 C70 T5 Conv, it have about 104k miles that I just bought. The car drives good, needs work but over all well.
I have replaced the PCV system and did a tune up. This is my first Turbo car so I am still learning.
My question and I appreciate the help :). While driving at any speed and then take my foot of the gas, the rpm starts dropping in linear fashion. However, once the rpm drops to about 1500 I then drops about 200 to 300 at once. Is this normal?
Thank you :)
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
I read this post earlier and payed attention to my RPM's today. What your describing doesn't seem to happen too me. RPM's stay somewhat steady after I let off the gas. Then they slowly start dropping. I'm driving a turbo as well. I'm no expert but some will chime in.
1999 V70 GLT
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
Did this have the transmission flash done yet?
Tarek80
Has thanked: 1 time
Post by Tarek80 »
Hi,
I am not sure. I will have to take it to the dealer or is there a way I can check?
Tarek80
Has thanked: 1 time
Post by Tarek80 »
A quick video to show the issue
Has thanked: 1609 times
Been thanked: 4064 times
Throwing this out there
Are the engine rpms actually dropping or is it just indicating ?
Tarek80
Has thanked: 1 time
Post by Tarek80 »
Thank you for the hint!!
I used Torque Pro to monitor the RPM and it also showed the drop.
wizechatmgr
Any misfire codes stored? I almost wonder if that's a throttle module getting iffy...
Tarek80
Has thanked: 1 time
Post by Tarek80 »
Hello again,
I took the car to a local “ Volvo Specialist “ .. he checked for misfires and I also asked to update the TCM software. After couple of days I got the following
1. No misfire events
2. They couldn’t update the TCM software because they don’t have DICE bypass .. specialist if you ask me!!
However, they pulled the current ECU software part number 09480596A if that means anything ..
Now I need to take it to a Volvo dealer and see what they say.
I think the c70 stays P80 through 2004
