ABS woes, again
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
So for the second or third timw this year the ABS and TRACS light came on. I soldered the module 4 times in the past 5 years and the problem seems to come back.
Since I have a 96 I can't blink out the codes. I know that theoretically wheel sensors, the wiring to the sensors and the ABS rings could really go faulty. But over the years it were mainly the modules. I know the wires to the ABS pump are crappy, but I don't know how the remove the pump.
Now honestly, what xould I do to get that stupid ABS system to stage 0?
1996 855 R,
2010 V70 D5,
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
If you can find serial db9 to OBDII cable(Vag-Com kkl) i can send you Vol-Fcr via email.
Other than that...you can remove and clean out front abs sensors because....since they are magnetic...they can be fouled up with metal debris from pads and rotors.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Clemens
Post by Clemens »
I'vw had that cable for a while. I'll pm you my email address. Thanks!
1996 855 R,
2010 V70 D5,
