Idle issue
- Has thanked: 17 times
- Been thanked: 35 times
Could be many possible things that causes this. Since you changed your tranny fluid recently, check it to make sure it is up to the correct level. Other than this, I can think of fuel filter as well as throttle body needing cleaning- but they probably did that with the software upgrade. Others, hopefully will give their opinions.
Thanks for the info. i did have the throttle body cleaned when the ETM was upgraded. Any other ideas you can offer would be appreciated. It is really more an annoyance than anything else. My previous car was a Nissan Maxima with an engine and tranny that was smooth as silk.
2001 Volvo S60
