XC&), MY '04.
First happened a couple of weeks back: accelerating gently on open road, "reduce(d) power" message briefly appeared, engine cut out, pulled out of traffic and tried to restart but nothing. After leaving it a while to cool down (maybe 20 minutes), it restarted normally and I drove home. Later that same day, it started normally but when I tried to back out of parking space, it stalled repeatedly. Left it overnight and it started fine the next day. Checked all the usual things and cleaned the MAF with sensor cleaner. OBD reader gave me a P0102 code and nothing else. After resetting it, I get the same code immediately but it runs fine. Checked MAF connector and 12v, 5v and GND all check out. MAF reading seems odd (jumps between 0.25 and 0.5 g/s) but this could be the budget tools I'm using. The fuel pump and filter are relatively new having been changed a few years back. My car doesn't have a fuel pressure sensor on the rail.
I have a new MAF and happy to try that but wanted to know if there is anything I should look at before doing that.
Stalling at idle when warm P0102
- RickHaleParker
- Been thanked: 980 times
Possible source
- Flow too high:
- short-circuit to supply voltage in the signal cable
open-circuit in the ground lead
defective sensor
- Air leakage
contact resistance
Contaminated throttle body (TB).
short-circuit to ground in the signal cable
open-circuit in signal cable
open-circuit in power supply cable
Defective sensor
Active
Past
Past
- 1398 Views
Last post by goldxc70
- 7721 Views
Last post by enriquepr21
- 2746 Views
Last post by DeadEric
- 1268 Views
Last post by jonesboy1983
- 3563 Views
Last post by 93ForMe
