XC70, MY '04.
First happened a couple of weeks back: accelerating gently on open road, "reduce(d) power" message briefly appeared, engine cut out, pulled out of traffic and tried to restart but nothing. After leaving it a while to cool down (maybe 20 minutes), it restarted normally and I drove home. Later that same day, it started normally but when I tried to back out of parking space, it stalled repeatedly. Left it overnight and it started fine the next day. Checked all the usual things and cleaned the MAF with sensor cleaner. OBD reader gave me a P0102 code and nothing else. After resetting it, I get the same code immediately but it runs fine. Checked MAF connector and 12v, 5v and GND all check out. MAF reading seems odd (jumps between 0.25 and 0.5 g/s) but this could be the budget tools I'm using. The fuel pump and filter are relatively new having been changed a few years back. My car doesn't have a fuel pressure sensor on the rail.
I have a new MAF and happy to try that but wanted to know if there is anything I should look at before doing that.
Stalling at idle when warm P0102
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Your 2004 had the CEM water ingress, you can also look from underneath the dash with a flash light
- Has thanked: 1611 times
- Been thanked: 4075 times
The MAF reading jumping at idle is a good tip off, if you a trust the tool, of course
This is also a time where stopping the engine , unplugging the MAF . And restarting would have improved the idle. The problem with that approach is that same diagnostic points to many possible causes, not just the MAF
- RickHaleParker
- Been thanked: 980 times
Possible sourcegoldxc70 wrote: 26 Mar 2021, 10:45 Checked all the usual things and cleaned the MAF with sensor cleaner.
- Flow too high:
- short-circuit to supply voltage in the signal cable
open-circuit in the ground lead
defective sensor
- Air leakage
contact resistance
Contaminated throttle body (TB).
short-circuit to ground in the signal cable
open-circuit in signal cable
open-circuit in power supply cable
Defective sensor
Active
Past
Past
goldxc70
- Year and Model: XC70 2004
- Has thanked: 27 times
- Been thanked: 3 times
Five days later and car is running very nicely after swapping out the old MAF for a new Bosch. When I compare the scantool graphical outputs, it's very clear that the old MAF was faulty: air intake was not changing consistently or at all with changing engine speed. When it did change, MAF was capping out at a fraction of what it should have been, 0.5g/sec instead of 12 g/s.
- 459 Views
Last post by RickHaleParker
- 7748 Views
Last post by enriquepr21
- 2756 Views
Last post by DeadEric
- 1271 Views
Last post by jonesboy1983
- 3637 Views
Last post by 93ForMe
