GASOLINE ENGINE SOUNDS LIKE A DIESEL!!!! Topic is solved
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
VolvoK14
Post by VolvoK14 »
My 85 Volvo 760 (160,000 miles) since i bought it the engine shakes real bad even with the new engine mounts put in. Most of all it sounds like a diesel engine, it has this loud tapping sound when it idles and gets worse with acceleration. I've even overdosed on that Chevron fuel injector, valve cleaner. Anyone else have this problem, any suggestions?
Kyle
Volvo_Diesel
Post by Volvo_Diesel »
I might be going out on a limb, on this one but maby it is a diesel?
Volvord
Post by Volvord »
I am assuming that you have the V6 engine?
These engines use a chain driven camshaft, it is common for chain drives to make very loud rattlins sounds as they wear and stretch. Sounds like you need the chains and tensioners replaced. The V6 engine was also known for bad camshafts that would wear prematurely, as the cam lobes wear the valve/lifter clearence increases causing "clatter". Again replacement is the solution but this is a major job because the cams have to be removed through the rear of the heads so the engine or the heads must be removed.
http://www.Volvord.com
1998 C70
1989 744TI with a 400HP Ford 302 / 5 speed
