Rear seat belt electronics?
cleven
Year and Model: 2001 V70 T5
Has thanked: 1 time
Been thanked: 5 times
Post by cleven »
My 2001 v70 needs rear seat belts. Can I use some universal belts or does the Volvo have some electronics hooked up to the unit? Its like ZERO volvo's in the junk yards locally .
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
cleven wrote: 20 May 2021, 00:13 My 2001 v70 needs rear seat belts. Can I use some universal belts or does the Volvo have some electronics hooked up to the unit? Its like ZERO volvo's in the junk yards locally .
On my 04 v70 I think the rear seat sensor is to detect anyone sitting there.
If it detects a rear passenger it looks for the seatbelt to be buckled.
If it didn't set an SRS light I wouldn't bother, if you need it for inspection I'd just sling an old belt in there and fake it.
I failed on my old volvo 740 because the front belt was removed, so I pulled one from the rear seats and installed that.
they didn't even look at the rear seats.
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
On my 2001 V70 T5, the rear seat belts have a electrical connection to the SRS. If the SRS wires are not connected on start, the SRS will set a fault. This particular fault can not be cleared by most code readers.
jonesg
Post by jonesg »
volvolugnut wrote: 20 May 2021, 11:52 On my 2001 V70 T5, the rear seat belts have a electrical connection to the SRS. If the SRS wires are not connected on start, the SRS will set a fault. This particular fault can not be cleared by most code readers.
the sensor would be in the seat cushion.
Tripped it on mine when I did the fuel pump reseal.
