CV axle issues
befarrer
Year and Model: 1998 V70 AWD
Has thanked: 1 time
Been thanked: 24 times
CV axle issues
Post by befarrer »
Mt driver's front outer CV boot tore on me, I have been expecting this for awhile now. I heard that Volvo axles are the only way to go, so I got a replacement from the pick n pull yard, they had the same year and model V70 as me there. I had a heck of a time getting the axle out of the donor car. My old axle came out quite easily, but the replacement one is hard going in, it seems to be most of the way, but the last 1/4" is not going in. I tried pulling it out and it's also stuck. Also, this replacement axle I got is not a Volvo OEM one. My question is anybody had issues with aftermarket axles getting stuck, or not seating fully in the transmission?
98 V70 GLT AWD
05 VW Golf TDI
93 Mazda B2200 with 13B rotary engine swap
Has thanked: 1859 times
Been thanked: 1719 times
Yes!! Try and get it back out and swap the spring retaining clip from the original with the aftermarket one. They are often too large or badly made and no rounded edges so tend to bind.
If the CV boot on the original is not too bad, worth keeping it and getting a new CV boot and fixing it.
befarrer
Has thanked: 1 time
Post by befarrer »
I was planning on changing the boot. I caught it right away. I'll try to yank this one out, might have to jack it up higher to get larger pry bar in there. I think I'll just order a replacement boot and reinstall my old shaft.
98 V70 GLT AWD
05 VW Golf TDI
You can buy the spring clip from Volvo but not cheap.
Try to get GKN boots if you can.
xanthefin
Year and Model: 1997 850
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
I replaced mine outer CV with Meyle HD one. Been working fine on myself.
befarrer
Has thanked: 1 time
Post by befarrer »
All I am seeing is Doorman boots, that's probably what I will end up going with.
98 V70 GLT AWD
05 VW Golf TDI
No idea who makes them for Dorman. The rubber material is the issue with these as it is with many other rubber parts.
Availability in Canada is the issue. Autopartsway do them in Canada for the outer boot. Never use Empi!!
https://www.autopartsway.ca/partlist.cf ... enum1/tabs
mecheng
Year and Model: 1998 Volvo S70 T5
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
To get the driveshaft removed easily place a chisel between the cv housing and transmission. One swift hit on the chisel and it pops out easily. Without this trick I’ve suffered removing them
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
