So twice now, dearest spouse has mentioned she has trod on the accelerator, had the engine RPMs increase, but no corresponding increase in forward momentum.
Car had its 150K mile service recently and mileage is probably right about at 150K miles.
Any ideas what might be going on? No codes, no CEL. Wife says it tends to happen in high heat with AC on.
I have been unable to reproduce this fault.
2007 S80 3.2 FWD Auto -Not responding to throttle
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 120 times
- Been thanked: 189 times
Your problem sounds more like a transmission problem than a Engine or Accelerator pedal problem.
Try shifting into Manual mode and changing the gear when the problem occurs.
If the Transmission thinks that you are requesting neutral instead of drive it would do exactly what you have described.
What does the cluster show when the problem occurs D or N?
If you lean on the gear selector can you get it to go from D to N?
Good luck
Paul
Good luck
Paul
- E Showell
That was my sense of things as well. But thanks, for responding.
'95 855 auto (sold)
'95 855 auto (sold)
Check ATF fluid level to make sure you arent just down and the TC is running a bit dry. Unlike the engine, this wont damage it, it will just lose transfer of torque.
- 450 Views
Last post by Mike Langlois
- 17 Replies
- 4620 Views
Last post by oragex
- 16 Replies
- 4795 Views
Last post by MoVolvos
- 10798 Views
Last post by Sololaolu
- 6800 Views
Last post by br0dy519
