SC-810 radio question Topic is solved
lcc014
Year and Model: 855, 1995
Has thanked: 2 times
Been thanked: 11 times
Post by lcc014 »
I recently bought a used SC-810 radio to replace my old SC-710 radio. SC-710 radio has volume knob issue - either very low volume or very high volume. Volume control is almost not existing. Also, some LEDs are gone.
For SC-810 radio, I have 2 questions:
1) does it have "balance' control ? I could not find this function. In SC-710, "balance control" was part of the Volume knob function.
2) the backlight of LCD display is gone. Can the LCD display be replaced ? If yes then where can I find the part number and any instruction to open up the radio for LCD replacement ?
Thanks,
Ching-Ho Cheng
viper69
Year and Model: 850GLT 1995
Has thanked: 77 times
Been thanked: 2 times
Post by viper69 »
You would think it would have balance, it doesn't.
viewtopic.php?t=38385
Volvo 850 GLT 1995
5 Speed Manual transmission
122,500 miles and barely broken in
'82 Volvo DL Wagon, 4 speed manual
'77 Saab 99 EMS, 4 speed manual
lcc014
Post by lcc014 »
Thank you so much for the link. So the LCD backlight is not part of the LCD module, it is a separate bulb ?
Thanks,
Ching-Ho Cheng
Has thanked: 2207 times
Been thanked: 1852 times
Would it be easier to upgrade to an SC-815/816 with the tape and single CD player. They have the built in amps. We just has a 50% off at our local PnP and they sell for about $10-15 CDN.
Check with abscate. Chances are he is falling over them!
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
+1 for a known good SC-815.
lcc014
Post by lcc014 »
it is difficult to get a "completely" working radio (radio, CD, tape, backlight, etc) :(
If you can wield a screw driver, then replacing most of the bulbs in a Volvo radio is not too bad. There are how-to's out there.
Cleaning the cassette heads is not too bad with IPA and cotton buds.
Seriously, check with abscate, he has parted out a few cars so may have a spare kicking around.
I have a few here, but shipping often precludes sending to you.
Good Luck!
lcc014
Post by lcc014 »
I just found this video which showed steps by steps to replace the bulbs including the LCD backlight bulb in sc-816. It will be similar to sc-810 or other models.
I had ordered the new bulbs from DigKey. Once they arrive, I will change out all the bulbs.
Thanks,
Ching-Ho Cheng
If I recall, on some of the head units one of the bulbs is for the LED/LCD readout. Seem to recall this required a little more work.
Good Luck!
lcc014
Post by lcc014 »
Thank you for the head up. :)
