98 V70 NA- base MAF question
Has thanked: 1853 times
Been thanked: 1714 times
My young friends V70 stalled out on her today. No warning. It would hard start and then die with the foot off the gas.
After thinking about it (I don't do early mornings!!) I suggested she pulled the MAF wire and it started up and ran great.
New MAF needed. I believe the correct one is a Bosch #0280217107.
Lots of bad info out there listing this fits a variety of models but can't find it anywhere available locally. Interestingly FCP list another brand now as the OE part number and not Bosch which they show out of stock (Bosch Canada shows NLA).
Before I order this is it fitted to any other cars. I think I recall Rick listing a couple of SAABS.
Only source locally is Volvo which is a 3-4 day turn around and at a 'discounted' $422 + TAX CDN
I thought the 850's were fitted with this but a friend says his 95 has a Siemans branded unit on the NA motor and it is not the same style or fitment.
Any help appreciated!
P>S NAPA is trying their contact for a Bosch one but it was $500 CDN!!
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1248 times
Post by matthew1 »
Did you try Erie? https://www.erievovo.com/ They're in the States, but maybe shipping won't be too much.
I'm pretty sure all P80s used the same (Bosch) MAF.
Also -> Amazon link
Thanks Matthew. I would use US sources but it is the shipping time with the car being out of service. But like I said even the dealer has a 3-4 day delivery.
I will try PnP tomorrow (my wife has our car today as I have the XC70 in bits!) but that is usually the first part to go and they now charge $50 for them!!
Has thanked: 1507 times
Been thanked: 3824 times
Noooooooooooo.
Running welll on lookup table usuallly means vacuum leak, not MAF
Check flow rate on scanner to see if it’s working
But from where? NA has few air pipes for an issue. I have replaced all (well the majority) of the emissions pipework including the carbon canister. So where else?
Throttle body? Car has around 100,000 miles on it (or less). I know that is no guarantee. It suddenly happened today after running fine yesterday.
I can see if we can delay the order a day if it is not too late. That way it would give me a chance to get there and have a look for obvious leaks.
I was using this as a quick guide as it had the same symptoms:
viewtopic.php?t=99714
Has thanked: 293 times
Been thanked: 765 times
Post by erikv11 »
abscate wrote: 12 Apr 2022, 12:59
Noooooooooooo.
I think "usually" is not the right word here. More like "sometimes." By logic we expect it is either MAF or vacuum leak. Empirically it has always been MAF for me and I've seen it several times on the fora but that's a small sample size. Vacuum leaks usually give P0172, that's more useful info to consider.
Swapping in a good MAF to complete the test will enable you to differentiate.
93-94 is a different MAF
95-98 all the same, turbo or non-turbo. Maybe I am wrong about 95 NA, I've not owned one of those, but I don't think so.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Post by erikv11 »
Neil can you grab the MAF from the project 96? Guaranteed it will be the same one.
'06 S60 R, 197k
It was different. It is a Siemens part number I believe. Now maybe on a 96, but then if I pull that one the car won't move..........
Anyway this is the airbox from a 95 NA 10 valve:
95 850 NA airbox
95 850 NA airbox
95 Air Box and MAF.jpg (526.31 KiB) Viewed 365 times
Even I was surprised. I need to get the VIN# for the 96 to see if it up-changed. Did the software not change up then too?
Post by erikv11 »
The 96 should run w/out a MAF to, just like the 98 does.
OK 10 valve all bets are off - I am only referring to 20 valve engines. We didn't get those 10 V and I don't know anything about them.
95 was Motronic 4.3, 96-97 are transition years from Motronic 4.3 to 4.4., 98 all were 4.4.
But both of 4.3 and 4.4 use the same Bosch MAF.
'06 S60 R, 197k
