87 Wagon locks but does not unlock no Topic is solved
warmblood58
- Year and Model: 1989 245
- Has thanked: 5 times
- Been thanked: 2 times
My ring is correct on the driver door lock cylinder, I cleaned up the exposed 3 wires at the switch and at the actuator (exposed wire) and I get relay action which will close the locks but not unlock? Bad unlock solenoid? Has anyone accessed these recently? Hard to get to? Thanks!
- Has thanked: 987 times
- Been thanked: 1075 times
Can you apply 12 volts directly to the solenoid wires to see is the switch is bad? After 35 years the solenoid or switch may have given up. Switch might be cleaned and revived. Solenoid would likely need replacement.
Access solenoid by removing door card. It is below the lock.
warmblood58
Thanks, this saga began when GF broke off tip of key in driver side lock (yep, she's talented that way!) So replaced lock cylinder, action up and down was sluggish at that time, upon removing ring around lock cylinder I found all insulation gone from the 3 wires entering ring so I was able to insulate them and also repair a section of exposed wire at actuator. I was thinking of the solenoids (2) that are behind central vents, thinking that the open lock solenoid might have given up coincidentally when door panel removed, etc. There is a solenoid under lock actuator?
Maybe more wire damage. 1980's Volvos had wire insulation crumbling problems everywhere.
The lock actuator (solenoid) is located below the door handle and key lock. Sorry, I was confusing.
Do you have the door panel removed? Wait, I see you said it was on other post. Let's stick to just this one.
warmblood58
Door lock is also working as it should as I note that I can not push button down when door is open - I might exercise lock a few times to see it this helps
warmblood58
when I unplug/plug 3 wire connector that connects to actuator at door, lock buttons go down solidly but thats it. Driver door locks manually just fine --- oh boy, more fiddling around, I wonder if my lock cylinder ring is just plain defective . . .
What do you mean 'lock cylinder ring'?
warmblood58
SUCCESS! Well . . . I pulled actuator out to look up into cylinder to see if I had more bad insulation there but it look ok save for one tiny spot - reinstalled actuator, put key in lock and now have buttons lock and unlocking. I did also clean fuse 8 contacts previously which allows for better voltage transfer but the act of removing actuator physically and reinstalling changed something-who knows, could have been grounding out somewhere . . . ???
warmblood58
This is the black plastic circular ring that snaps around the lock cylinder that creates ground/ungrounded contact when the door key is turned in the lock thus creating lock/unlock in the door actuators.
- 1239 Views
Last post by DavidE7
- 1192 Views
Last post by nsjames
- 772 Views
Last post by MadeInJapan
- 715 Views
Last post by 93SCMax
- 28 Replies
- 1204 Views
Last post by koralski
