Any electrical geniuses here?
Did some meassuring once again
No spark problem also no CEL on dash when ignition is on (bulb maybe burnt) and no power on A26 and A27 on ecu pins but got 12v on A12 when ignition is on
Blue wire on ignition coil 12v drops to 10 when cranking (should be waayyy Lower apparently)
Red wire on ignition coil 12v as it should
And i get no voltage on b11 on the ecu pin while cranking (should be 3-4v)
From engine harness Pin 1 on CAM sensor is 0 ohms (as it should)
Pin 2 on cam sensor 0 (should be 5v)
Pin 3 on cam sensor 12v (as it should)
96 855 no voltage on cam plug and other places.. Topic is solved
- Has thanked: 2197 times
- Been thanked: 1851 times
Being a Euro spec car, does it have an immobiliser and chipped key in 96?
Neil
Neil
The immobilizer is long gone (bypassed) and should not cause these issues either..the car would start and then die not cut spark just fuelscot850 wrote: 15 Jan 2023, 10:10 Being a Euro spec car, does it have an immobiliser and chipped key in 96?
Neil
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Main fuel injection relay(grey one) on fan shroud?
Not having lambda light with ignition in posII along with all other lights means that ecu have no power.
Fuse no.1 ok?
Fuse no.1 ok?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 3896 Views
Last post by erikv11
- 14 Replies
- 3156 Views
Last post by jvl
- 5549 Views
Last post by hans747
- 36 Replies
- 20889 Views
Last post by Achilles
- 1443 Views
Last post by shiloh51933
