Our car was towed last week; upon picking it up at the tow yard in Denver, it would only move 20 feet before the engine stalled.
I ordered a new MAF from Penguin Parts and installed it, but the same issue with stalling persisted. Two possible issues from
\reading forum posts. Always use a Bosch MAF. There is probably an issue with a vacuum leak, because a hose is missing from
the pipe downstream from the MAF, as shown it a picture. The underside picture of the engine doesn't show any obvious destinations for where to attach the missing hose. If someone has a suggestion, I'm open to it. Just in case the open port is a problem I can try buying a cover for it.
1998 Volvo V70XC replaced MAF (non-Bosch), drivability issues (stalling out)
rocky_mtn_man
- Year and Model: XC70 1998
- Has thanked: 1506 times
- Been thanked: 3819 times
Look under hood on the right side for a sticker with the vacuum hose routing. They vary between models amd engines in a given year, so you need your diagram. That might be the fuel pressure regulator vacuum supply, needed
- Has thanked: 293 times
- Been thanked: 765 times
Yes it goes to the fuel pressure regulator but check your sticker to be sure.
See bullet point #3 in this post: viewtopic.php?t=63615
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
Here is my 1998 turbo sticker.
- Has thanked: 927 times
- Been thanked: 1002 times
No turbo sticker found.
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 126 times
What happens if you unplug the MAF entirely? Should still start but run really rough.
- Has thanked: 2656 times
- Been thanked: 1248 times
@rocky_mtn_man this might match your XC70 https://www.matthewsvolvosite.com/vacuum-lines/
Its a tough, demanding crowd here....
viewtopic.php?p=669472#p669472
Old guys with little else to do......abscate wrote: ↑08 Oct 2025, 08:34Its a tough, demanding crowd here....
volvolugnutr
- 9 Replies
- 7019 Views
Last post by enriquepr21
- 859 Views
Last post by Uglyveedub
