Gas gauge is reading in liters and not gallons?
2013 S60 T5 AWD Engine Swap - DIY Basics
I'm pretty sure that all of the Volvo instrument clusters are in gallons at least if your main speed read out is in MPH.
its not saying 18 liters it is 18 or i believe an 18.5 gallon tank. to compare it to mine it should step down like this [18/12/6/2]
18 liters is also only 4.7 Gallons so that would be one tiny fuel tank!
1998 S70 T5 SE 214,001
1999 v70R 126,000
1999 v70R 126,000
VCA
- Year and Model: 2008 S80 T6 AWD
- Been thanked: 5 times
Correct, it's an 18.5 gallon tank, and all instrument cluster modules in North American and Asian markets (not sure about Euro market) display fuel in gallons. You'll have either 18 or MAX as the "full" indication depending on whether you have a Motronic 4.3 (pre-'99) or CAN ('99-'00) cluster.peacock wrote:I'm pretty sure that all of the Volvo instrument clusters are in gallons at least if your main speed read out is in MPH.
2008 S80 T6 AWD
1999 S70 GLT
Responsible for the care of a '92 960 and an '07 S60R
1999 S70 GLT
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
19.3 gallon tank to accomadate the expansion of the petrol. When filling up, the pump will only fill it up to 18 and some change gallons.
Which apparently you should never overfill by a lot because it screws up some sensor? Is that correct?polskamafia mjl wrote:19.3 gallon tank to accomadate the expansion of the petrol. When filling up, the pump will only fill it up to 18 and some change gallons.
Also, apparently S70 non-turbos have a 68L capacity while turbo have 70L. Given that AWD takes more space, how did they manage to expand the gas tank by an extra 2L?
2000 Volvo S70 SE; First Owner; 321km; Retired
2012 Volvo S60 T5 Level II; Gone
polskamafia mjl
No, it doesn't mess up any sensors. But you are right you shouldn't do it becuase it will force excess petrol into the EVAP system and charcoal canister.
- 254 Views
- 29 Replies
- 7601 Views
- 599 Views
Last post by PanMaxon
- 15 Replies
- 1906 Views
Last post by matthew1
- 1181 Views
Last post by alschnertz
