2001 Volvo S60 2.5 turbo
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
Re: 2001 Volvo S60 2.5 turbo
Yes; they will be able to look it up by your VIN number and tell you whether or not your car is eligible to begin with.
'98 S70 T5
2016 Chevy Cruze Premier
JRL
- Year and Model: Several
- Been thanked: 16 times
Yeah but they need to do a bunch of tests before they're giving out these $800 units.douglfrench1 wrote:No, I am not driving it. Do I just contact the Volvo dealer about the warrenty?
If it's that bad it should have a red ETS light on the dash
douglfrench1
- Year and Model: 2001 s60
I finally got the code for my 2001 S60! A mechanic told me it was giving the code P0121? I believe something about throttle body? I called Volvo and gave them my vin# and the warrenty is good until 7-7-2011. They said if that if it wasn't the emt then I would have to pay for the diagnostic. $112.00. If it is the emt then Volvo would cover everything. Any imput is greatly appreciated.
Thanks,
Doug
Thanks,
Doug
JRL
If you have an ETS code
It called an ETM but the code thrown I believe is "ETS"
(NOT EMT, that's someone who comes in a big red or white truck and can save your life)!
If the light is on they will go thru steps. First they will clean it on their dime.
If that doesn't work you will give a new one so get it to Volvo.... NOW!
douglfrench1
Thanks, sorry about "emt" If you haven't already guessed, I am not very knowledgable when it comes to cars! So is the P0121 something that is covered under the warranty we talked about? What does "etm" and "ets" stand for?
Thanks,
Doug
Thanks,
Doug
JRL
Electonic throttle systemdouglfrench1 wrote:Thanks, sorry about "emt" If you haven't already guessed, I am not very knowledgable when it comes to cars! So is the P0121 something that is covered under the warranty we talked about? What does "etm" and "ets" stand for?
Thanks,
Doug
Electronic throttle module
or some call it ETB (which is actually it's correct name)
Electronic throttle BODY
douglfrench1
I hope so. I am going to have it towed to the Volvo dealer Monday. Thanks for all your help!
douglfrench1
I had my car towed to the Volvo dealer to see about the etm and they said my wiring harness had been spliced and they would not work on it until I replaced it. About $3000.00!!!! does anyone know where I can get a used one cheap?
- 1801 Views
Last post by cn90
- 1747 Views
Last post by darylrobert
