Thanks, really. The very detailed pictures and instructions helped me change all my plugs. I enjoyed the work and the money I saved. I wouldn't have done it without having seen these pictures.
Thanks
2001 V70 2.4T bad ignition coil replacement...
2001 Volvo V70 2.4T ignition coil replacement tutorial
trackminer
- Year and Model: 1999 S70, 1986 244
Awesome post Sir!
...pullin' off slow - in a VOLVO...
Lead Chalcogenide
- Year and Model: 2001 XC70
Seriously? I have unplugged my MAF several times with no change to engine performance. I even drove about 1 mile (in a deserted parking lot) with the MAF unplugged. Maybe I need a new MAF as well. Thanks for the tip.1911colt wrote: so I unplugged the MAF and the engine kept running, it should have died immediately,
Lead Chalcogenide
okay... no.
I went out an bought a new MAF based on this thread and no dice. I still have a major problem. So, in my case, (failed acceleration, or useless gas pedal), when I unplugged the MAF, it had no effect on my driveability, yet the MAF was fine. Just putting that out there for reference.
baylorbrown
- Year and Model: V70 2000
Thanks. This write up was a huge help to me!
-Ryan
-Ryan
blueturfjunkie
- Year and Model: 1999 V70 wagon
Thank you! Like you said, the car wouldn't idle, 'it would, but rough', but I think the tell tale sign was the shaking steering wheel. At any speed. Except when decelerating. then it cleared up. Hit the gas, shaking wheel. Just that little bit of info was huge for me in diagnosing the problem, My V70 needed a new ignition coil. All I did was replace all spark plugs (Champion Double Platinum Power Premium Plugs), found the one that was wet, And viola! I knew exactly which coil to replace. $18.00 for plugs.$51.99 for coil, and the car runs like new. 118,000 on the wagon, Just acquired her three months ago, hope I didn't make a mistake. Several yellow lights staring at me.
Whitebird
- Year and Model: 1999 S70 Base manual
Wonderful tutorial with great pictures. I want to chime in to say, 'Thank you' to E170_Driver and to confirm that these instructions for changing plugs and coils work for the 1999 S70 (non-Turbo) as well.
Wish we had done this sooner. Couldn't believe how easy it was to replace all five coils. (I wasn't taking a chance on just doing one). Car started up this morning without the check engine light on. We couldn't have done it without your help!
All 5 is a-bit of a financial stretch especially if buying OEM. which aftermarket one did you choose if you did? At first symtoms of bad ignition coils I cut the 'skirt' from bottom approx 7mm just right above the 'shoe' so it doesn't touch the plug's chassis. It prolongs life to about 6000mi extra.
- 14 Replies
- 9147 Views
- 13 Replies
- 1644 Views
Last post by Sommerfeldt
- 1674 Views
Last post by RickHaleParker
- 18 Replies
- 15107 Views
Last post by LadieRed
- 2923 Views
