Big brake brackets... and cost to upgrade to 302mm rotors
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
As said above, big brake kit will NOT fit 850 wheels.
'98 S70 T5
2016 Chevy Cruze Premier
KaferChris
- Year and Model: 1996 850 Turbo
I have no problem with clearance to the wheels, I'll be picking up some 17" rims. I already installed new Stoptech pads and 16" braided lines...and have some 302mm ATE rotors as well...I need confirmation about the correct bracket/part #.
- Has thanked: 2856 times
- Been thanked: 1332 times
Do yours say "Ate 485"? Attached above are the ones I got used -- not yet installed -- so I can't say 100% that they are correct 302mm front brake caliper brackets.
KaferChris
No they do not, but you can tell from the photos that the brackets I have are entirely different
So now that we know Jesse has bad dope, what do we think about trying his other suggestion?
Thank you.
Thank you.
Longer brake lines?
Longer brake lines?
KaferChris
IVIUSTANG wrote:Last time I checked, OEM brackets are less than $50 each. There are two types, each with a different part number, the only difference I believe are the finishes on them. 8602456 or 8251319 both should work.
- Jesse
Chris, I don't know. Can't speak for Jesse.
But FCP clearly lists #8602456 -- http://www.fcpeuro.com/products/volvo-c ... rs-8602456 -- "Volvo Caliper Bracket (302mm Rotors) Genuine Volvo 8602456"
The other part # is less certain -- http://volvospeed.com/vs_forum/topic/97 ... -brackets/ -- there's a thread where someone asks about it.
- famfeld
- Year and Model: 04 xc70
- Been thanked: 6 times
I remember a link where someone shaved a bit off of the calipers to get clearance for stock rims after doing this upgrade. Can anyone please direct me to that post/write-up? Thanks,
-Feld
-Feld
rguzz
- Year and Model: 1996 850 turbo
- Been thanked: 25 times
https://www.matthewsvolvosite.com/forums ... =1&t=49165
See below "similar topics". Seems pretty controversial overall opinion appears to be don't do it.
- 979 Views
Last post by filipe martinho
- 1069 Views
Last post by benpineapple
- 1042 Views
Last post by rguzz
- 12 Replies
- 2767 Views
- 1043 Views
Last post by Chuck W
