Would replacing gasket on 2 year old water pump...
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 116 times
Post by xHeart »
... be my second step if the minor drops do not stop after I re torque these 7 bolts?
Timing belt was done Oct 2010. What all I must remove to access these bolts? Would someone point me to the pertinent MVS posts.
Weekend project. TIA.
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
xHeart wrote:... be my second step if the minor drops do not stop after I re torque 7 bolts?
Just in case that the coolant is escaping from a bad seal.If it is escaping from the little shaft,you must replace it soon.
I assume that you have OEM or Hepu water pump installed.They are the ONLY one you would want to have in there.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
jimmy57
Been thanked: 320 times
Post by jimmy57 »
First know where it leaks from. The bolts at 1 o'clock and 2:30 can leak by threads. The bolts can have sealnt applied and fix that without removal of belt.
xHeart
Post by xHeart »
jimmy57 wrote:First know where it leaks from. The bolts at 1 o'clock and 2:30 can leak by threads. The bolts can have sealnt applied and fix that without removal of belt.
The location is designed for braille readers. Would a socket set with 1/4 and 3/8 driver sufficient, and what sealant?
Few photos...
view from below, a drop at a time
corner with antifreeze
Yes. it is HEPU.
HEPU!
HEPU!
jimmy57
Post by jimmy57 »
I thought all along we were discussing the 01 XC70. The hydraulic tensioner on the 97 makes this a bit different. If the leak is traced to the bolts then the belt has to come off.
Teflon pipe joint compound/thread sealant would be fine. Loc-Tite makes a teflon bolt sealant but for two bolts it would be more expensive and harder to locate than the ACE/Home Depot/Lowe's/Menard's available plumber's product.
xHeart
Post by xHeart »
jimmy57 wrote:The hydraulic tensioner on the 97 makes this a bit different. If the leak is traced to the bolts then the belt has to come off.
'97 850 N/A - I took the TB cover off the other day, it is difficult to size up looking from the above. Would removing the passenger side wheel help?
misha
Post by misha »
xHeart wrote:...it is difficult to size up looking from the above. Would removing the passenger side wheel help?
Remove the passenger side wheel and bend a plastic shield to reveal crankshaft and all other timing components.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
xHeart
Post by xHeart »
Ozark Lee wrote:There are a couple of versions of the crankshaft marks. Some have two marks and others have one mark.
There are some pictures in this thread.
https://www.matthewsvolvosite.com/forums ... =1&t=19831
Above is quoted from a topic discussing timing belt. Ozark Lee's write up is an excellent starting reference for me to take on the leaking issue near the water pump. My scope of work is limited to water pump, but it looks I will have to do everything before I take the pump off. The markings, alignment, minus putting new parts since the TB job was done by Volvo service 2 years ago.
If so, then, would it make sense to order the water pump kit before taking it all apart?
xHeart
Post by xHeart »
The bolts appear dry. However, pressing against the cup with finger draws out antifreeze from its edges. It is hot.
location of leak
location of leak
A clearer view of drop forming. Would the seal become so weak that the hot antifreeze would start to gushing out at some point?
here is a drip forming after it is pressed
Where do I go from here? The Aisin kit at IPD if $78.
misha
Post by misha »
With that minor drops and with last replacement 2 years ago...i would let it there for next timing belt replacement and i would keep en eye to coolant level.In fact...you don't need to keep en eye to coolant level because you have low coolant light. :wink:
Seriously...if the pump is not making noise and don't have a play in the shaft,with that minor leak...i would leave it in there for next timing belt replacement IF leaking is not getting worse.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
