would water pump work without timing belt HoopLa...
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 116 times
Re: would water pump work without timing belt HoopLa...
Post by xHeart »
Progress. Belt is off.
off crank gear
off crank gear
xHeart
Post by xHeart »
With a thin coat of RTV, AISIN water pump is on. Bolts are all the way in comfortably, firm but not torqued at this time. RTV cure time is 24 hours. I would torque the bolts once cured.
I received the OEM TB kit today, new rollers are stiffer than those removed. The tensioner came with a plastic piece, that wasn't there with old one removed.
The shank in thermostat is soaked with PB Blaster. This could cause more trouble if not handled carefully.
A very productive day today. I think it could be running Saturday afternoon.
xHeart
Post by xHeart »
The thermostat shank removal is complete, details here...viewtopic.php?f=1&t=50844.
Used cn90's tips and tricks for thermostat replacement.
new T40 screws with new blue box Wahler inside...
Water pump and all tb components are installed. All torqued to specification.
Belt was slipped in from below easily, now around the crank gear, but a few teeth short coming to tensioner roller. There is bit of a slack before the intake cam.
Not thinking clearly.
xHeart
Post by xHeart »
Great start this morning, belt couldn't stand my advances. I now have water pump and tb components fully installed.
Timing marks are holding firmly. I am about to start the two turns on crank.
Moving on the next steps.
If all goes well, I will switch to zerex coolant after two cycle of wash with distilled water. Then only I would have restored the cooling and heating system with all new components.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
That thermostat housing looks new.
xHeart
Post by xHeart »
rspi wrote:That thermostat housing looks new.
I treated the housing with citrus cleaner, and scrubbed it a little.
I am sipping afternoon tea for a very productive morning. I have accomplished each task outlined for this cooling and heating project.
It is running again. Thank you all so much.
Some of you pointed to PCV early in this thread, so I tested it. It looks suspicious to me, will post photos with new topic.
Thank you again.
rspi
Post by rspi »
PCV system... Will that be a new thread for you. LOL Or will you seperate it into 3. :)
Here's my take, if you don't know if it's been done in the past 50,000 miles, as Nike says it best... Just Do It!
