These are steering fluid lines at the steering gear.
By proximity and function, it only take the open wrench 16mm and 18mm, but difficult to grab from below even with the subframe lowered. Without taking it off first accessing u-joint appears harder.
Rust tight, any note of precaution, and suggestion for a better placement of wrench. I have it soaked overnight with PB blaster.
Need a rebuild TRW rack for 97-850
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
xHeart
Rebuild Volvo - TRW rack arrived from J.A.C.
xHeart
After adjusting the front a little, all five steering gear bolts are cleared of subframe.
xHeart
After few days of struggle, I discovered crowfoot flarenut. Worked perfectly for taking off the two fluid lines at the steering gear with 3/8" extension and wrench.
I was surprised that the nuts were 3/4" and 5/8", and NOT 16mm and 18mm.
Added both SAE and Metric sets to my toolbox.
xHeart
A supplement exploring Pitman puller /viewtopic.php?f=1&t=54914
I am now reworking my steps after reviewing following diagram, it shows steering shaft, u-joint and steering column's lower part #10 via rubber boot #30 and a collar #29.
xHeart
The photo below shows a inside the cabin end of u-joint connected to lower steering column. The pinch bolt at the u-joint prevents the steering shaft to come loose even if it was hit from the steering shaft end.
It would make sense to remove this pinch bolts (see diagram #32). This would free the u-joint from the lower steering column, and then slide out complete (see diagram for #31) together with steering rack.
This method would eliminate all reasons for it getting damaged in the process. Any unknown?
xHeart
A view at the engine.
xHeart
Photos of my progress.
The upper of the u-joint which connects to lower part of the steering column is free. It can now slide out with steering rack.
xHeart
I must say, rack removal is a test of man's patience.
After back and forth for 3 hours, the steering shaft took 60 some degrees of rotation to clear the rack through the obstacles.
The absence of the two fluid lines would have made it bit more easier. It was after removing the clamp that keeps the line together near radiator, few inches above the bracket to the subframe, that the fluid line allowed the rack to come out the passenger side. All clamps keeping the fluid lines together were removed completely. This is a LHD car.
The oxygen sensor looks bruised. Who knows what else, I will check.
- 985 Views
Last post by Matty Moo
- 1901 Views
Last post by E Showell
- 321 Views
- 9 Replies
- 2691 Views
Last post by shiloh51933
- 738 Views
Last post by vtl
