1999 V70 T5 Ignition Switch replacement with Pictures 9447804
Ignition Switch Repair: Electrical Fix - 1999 V70
Re: 1999 V70 T5 Ignition Switch 9447804
Thanks for this excellent explanation, my electrical problems were more or less identical, when starting, the horn, window motors, heating/airco fan, radio, wipers, all didn't work. Two times, after driving 2-5 minutes, everything worked, the 3rd time driving, problem persisted. So, it looked similar to issues, linked with ignition switch, but in this case it came down to a faulty relay, hidden somewhere below a fuse box, when that was done, all was fine again
- Has thanked: 1503 times
- Been thanked: 3817 times
Adding to thread
Not all pins on the electrical connector are populated - on my car, this is what they look like
YMMV
YMMV
mynoralvarez
- Year and Model: 850 GLT 1995
To be totally honest I fear those buggers! I think they are hard to replace because of they are hard to reach.RayCis wrote:Thanks for this excellent explanation, my electrical problems were more or less identical, when starting, the horn, window motors, heating/airco fan, radio, wipers, all didn't work. Two times, after driving 2-5 minutes, everything worked, the 3rd time driving, problem persisted. So, it looked similar to issues, linked with ignition switch, but in this case it came down to a faulty relay, hidden somewhere below a fuse box, when that was done, all was fine again
- Has thanked: 2652 times
- Been thanked: 1245 times
Entered into Volvo Repair Database. Great writeup, abscate.
Which relay is that?RayCis wrote:Thanks for this excellent explanation, my electrical problems were more or less identical, when starting, the horn, window motors, heating/airco fan, radio, wipers, all didn't work. Two times, after driving 2-5 minutes, everything worked, the 3rd time driving, problem persisted. So, it looked similar to issues, linked with ignition switch, but in this case it came down to a faulty relay, hidden somewhere below a fuse box, when that was done, all was fine again
1996 850 Turbo Wagon - 175K miles, ARD Green ECU, Koni FSD, IPD sways, Snabb intake pipe, IPD HD TCV
1999 V70 T5M - 220K miles, M56H swapped, 2004 S60T5 engine, IPD sways, H&R springs, Bilsteins, TME catback, tune
2007 V70R, 55K miles, mostly stock
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I received my new switch yesterday, installed the new hardware. I drove the car to work this morning and it is running much better than it was,......but....I traveled about 25 miles and SAME ISSUE.....
.....I lost my instrument panel, speedometer, tachometer and the ABS and Brake lamp lit up......I read that someone had similar issues and it turned out to be a relay?
Can you provide some detail on this? WHat/where was the relay. Did you lose your instrument panel, speedo and tachometer? My abs and brake light lit up as well...
