BESIDES UNCLIPPING AND UNSCREWING SENSOR THAN REPLACING?
Changing w/ bosch #17070
does the check engine light go off after replacing and starting?
2000 S70 GLT Any Tricks To Replacing O2 Sensor
Reason: Lowercased title, please no ALL CAPS in titles. Review forum rules.
WARCOY99
HOOK 'EM!
HOOK 'EM!
- Year and Model: Lots
- Been thanked: 128 times
Reading fuel mixtures happens straight away so code will disappear once the new O2 sensor is plugged in.
This is assuming the O2 sensor itself was causing the 02 light.
- misha
- Has thanked: 152 times
- Been thanked: 402 times
You will need Denso O2 sensor for your car,
not Bosch.
not Bosch.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 1506 times
- Been thanked: 3822 times
Lots and lots of PB blaster applied over 2-3 days, don't drive car in between
mikealder
- Year and Model: V70 2000
- Been thanked: 13 times
If the car doesn't have a turbo you can fit a Denso DOX-1419 as that is what it had fitted from new, these can be found slightly cheaper than the OEM probe and the only difference is the box it is supplied in.
I fitted one of these to my V70 N/A engine MY2000 just under two years ago and it has been fine ever since - Mike
- 9 Replies
- 815 Views
Last post by befarrer
- 3878 Views
Last post by Volvofan94
