Yeah they CLEAR codes very well, but depending on which year you have reading them can be challenging.
As yours is '96 that's early as far as compatability. The later cars seem to work better. My 2000 V70 reads 4 throttle codes with a faulty throttle installed so that's not bad.
Real Time Engine Monitoring with Smartphone - Questions
Smartphone Apps & Volvos
- Year and Model: Lots
- Been thanked: 128 times
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
I've found that if you trigger a code, fix the issue and still have the light some of the scanners won't see the code because the condition is no longer there. The light would eventually turn it self off. I tested this some by running my car, unplugging the maf to trigger a P0102. Scanner picked up the code while the engine was still running (it stalled pretty quick though). I plugged the MAF back in, started the car and the CEL was on but no codes would pull. Cleared the code, cel went out and stayed out.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
c70_lindsay
- Year and Model: 99 S70 T5.
Would this set up read boost levels for a car( 2000 C70 hpt) if the car doesn't have a boost gauge on the dash?
The boost sensor is already reporting to the ECM. The vacuum guage becomes a boost sensor as boost goes on and off.
When the same screen I posted above is connected to my S60 AWD it constantly changes state from Vacuum to Boost and the guage name/scale changes (so cool) depending on throttle/ load.
- BlackThunder
- Year and Model: 1997 850
- Has thanked: 6 times
- Been thanked: 3 times
I've been using Torque for years. First with my HTC Hero and now with my Samsung Galaxy S2. I use an ELM 327 OBDII tool. In fact I have kept my old phone (HTC Hero) around to keep as a dedicated data tool for the car. It is also fun to use Torque's HUD mode to display data on the windshield while driving.
I'll echo that this was a great buy for me. I've been using this on my 1997 Volvo 850. I just got a 2013 C30 and I haven't used the OBD II tool or Torque on it yet.
Also, it is helpful to have this tool in your car so when someone else's check engine light comes on you can help.
Also, Tech support from the Torque developer himself has been great.
Dustin
Dustin
Dustin
2013 Volvo C30 T5
1997 Volvo 850 NA Sold to a New Volvo Enthusiast
2013 Volvo C30 T5
850_GLT_Owner
- Year and Model: 93 850, 97 850R
I just got an ELM327 adapter(~12)and torque for android(4.95). It is pretty cool though I haven't had that much time to tinker with it. It pulls a lot of stats and information, but I'm not 100% on the accuracy of the reaedings. I have a boost gauge that gets different readings than the digital read out from the ECU. I'm not sure which one is off. There are add ons for torque that can give you even more readings, and specialized add ons for different manufacturers. I wonder if ARD or anyone who has knowledge of volvo ECUs would put out an add on that is more volvo oriented.
Forget clearing SRS codes; unless you find another thread here on Matthews which for me seemed to require an associate degree in computer programming in order to understand how to achieve this.
Not sure about ABS codes.
They definitley clear the transmission codes as my 2000 V70 had a transmission code the other day; my ELM cleared it as I drove and my 1st and 2nd gears kicked back in.
mtd240
- Year and Model: 2007 XC70
- Has thanked: 23 times
- Been thanked: 7 times
Sucks that iPhone can't do any of this..
2007 XC70, white/oak, 175k miles
2008 XC70 3.2L, 115k miles
2016 XC60, osmium grey / off-black, 95k miles
Gone:
1990 240 DL Wagon, M47, lots of goodies. 372,000 miles
1978 242, lots and lots of work to get a reliable daily
1998 V70 XC, Almost done replacing everything, then I sold it
1996 850 NA, victim of sporadic tree falling. Protected the wife. RIP Volvo
Gone:
esl_97_850_T5
- Has thanked: 18 times
- Been thanked: 27 times
beigg,
1. An ELM327 device or an ELM327 compatible device (eg, an OBDLink SX, OBDLink MX, etc) can clear ABS, Auto Trans, and SRS codes for your '97 850. Instructions are included in the post dealing with How to read/clear SRS, COMBI, Power Seat, ABS, Auto Trans DTCs on a 1996-1997 Volvo 850 using an ELM327 .
I strongly suggest a slight change to those instructions to add a "ATRA 13" command before or after each "ATTA 13" command. That "ATRA 13" command will eliminate the need for the ATBD commands for ECU 01 (ABS) and ECU 6E (AW 50-42).
To interpret the DTCs, see the section "To interpret the SRS DTCs" in that post. That section can be adapted for each ECU.
2. If you have a WinXP or Win7 computer, have Internet Explorer installed, and are willing to download Realterm, then the far easier (and more powerful) ELM327-based approach is to use volvo850diag, since volvo850diag has "Clear DTCs" buttons to accomplish the ABS (ECU 01), Auto Trans (ECU 6E), and SRS (ECU 58) clearing.
To find volvo850diag, search for volvo850diag.zip in the thread containing the above "How to read/clear SRS, ..., ABS, Auto Trans DTCs on a 1996-1997 Volvo 850 using an ELM327" post. Also, you might want to check out items 6c and 7 in this post:
obdlink_sx_stn1100_family_elm327like_alternative_98_v70_combi_abs_srs_etc_access_scanner_elm327.html
in a brickboard thread detailing part of the actions that Mike91 took to enhance volvo850diag so it could be used with 1998 V70 and XC70 and with the ELM327 compatible OBDLink MX and OBDLink SX devices. Item 6c includes concrete examples of how to edit the .js file that comes in the volvo850diag.zip distribution to add the "ATRA 13" command. Item 7 helps with the Realterm and volvo850 diag setup.
esl_97_850_T5
esl_97_850_T5
1998 Volvo S70 GLT - 205.5K miles - S70 & M44 testbed in 2016-2019; traded 2019-07-15 (for spare time)
1997 Volvo 854 T5 - 147K miles - 850 testbed in 2012-2017; junked 2017-09
- 1663 Views
Last post by XC70Rider
- 3711 Views
Last post by ggleavitt
- 10 Replies
- 2798 Views
Last post by KTTYR
- 10 Replies
- 2298 Views
Last post by hanacaptain
- 25 Replies
- 7112 Views
Last post by Blacklab467
