DIY: Serpentine Belt EZ-Tool (<$2) & Routing Topic is solved
How to Replace the Serpentine Belt on Your Volvo 850 (and S70, V70, C70)
- osman
- Year and Model: 2002 c70 hardtop
Or use a tool we all already have: a 1/2 inch extension on a socket wrench, push it in all the way until it lines up with the 4 splines.
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
99 XC70 AWD LPT 115
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I tried a few times to get a 1/2" extension in there to turn it and could not.
The tool I had made I've been selling for $8 shipped.
- osman
The hole is bigger than 1/2" its the 4 splines all the way in that make a perfect 1/2" square, You just have to make sure that the 1/2" extension drive is all the way in AND oriented right (the square of the socket drive and the square formed by the splines) otherwise the splines prevent the extension from seating properly in the 1/2" square and when you turn the socket wrench the drive just turns inside the tensioner because it is not far enough in and not fitted into the splines.rspi wrote:I tried a few times to get a 1/2" extension in there to turn it and could not.
Brick Life
99 XC70 AWD LPT 115
99 XC70 AWD LPT 115
- osman
This is a picture of both
heres a pic of a 1/2 extension all the way flush inserted into the tensioner. Hint: The wobble extensions will actually "snap" in so that you know you are in right.
here is another from the side
Brick Life
99 XC70 AWD LPT 115
99 XC70 AWD LPT 115
- osman
So what exactly is that block thing that the crescent wrench is attached to, because it sure isnt part of the tensioner.eld4au6 wrote:You all do know you can use a open end wrench on the tensioner. No need for a tool.
its on the pulley below the shown wrench and tool.
Brick Life
99 XC70 AWD LPT 115
99 XC70 AWD LPT 115
- osman
this should be self-explanatory
Brick Life
99 XC70 AWD LPT 115
99 XC70 AWD LPT 115
eld4au6
- Year and Model: 96 855R, 96 855R
Im talking about the square-ish end of the tensioner that the idler pulley is attached to, can remember what size it was but I used a open end wrench from the bottom of the car.osman wrote:So what exactly is that block thing that the crescent wrench is attached to, because it sure isnt part of the tensioner.eld4au6 wrote:You all do know you can use a open end wrench on the tensioner. No need for a tool.
- osman
I think you have a tensioner that someone has jammed one of these home made inserts into, because that is not a part on any of our cars.
Brick Life
99 XC70 AWD LPT 115
99 XC70 AWD LPT 115
- Been thanked: 504 times
osman,
I think I know what "eld4au6" is talking about.
If RED is the usual way of doing this, then BLUE is what "eld4au6" refers to.
Basically:
- Adjustable wrench from below the car.
Here is my sketch, correct me if I am wrong...
Basically:
- 425 Views
- 22 Replies
- 35841 Views
Last post by erikv11
- 20 Replies
- 17402 Views
Last post by Hurtfeelings
- 3066 Views
Last post by jreed
- 1437 Views
Last post by skunkd84
