1996 850 interference
Is the Volvo 5 cylinder engine an "interference" engine, meaning that the valves and pistons will collide if the timing belt breaks? Thanks!
- misha
- Has thanked: 152 times
- Been thanked: 402 times
20v (B5254 & B5204) are interference ...but i heard that 10 valves engines are not.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 292 times
- Been thanked: 765 times
To the original poster: the US spec cars are 20 valve. All of those 5 cylinders are interference engines.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- Year and Model: Lots
- Been thanked: 128 times
I've worked on the 10 valve (B5252S) 5 cylinder engines and they're interference motors; flycuts on pistons means that's the case.
- misha
Nope...engine management is totally different.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Clemens
- Has thanked: 473 times
- Been thanked: 219 times
it is also not possible to swap a turbo-motor into a non-turbo-body. on p80 Volvos what you get is what you've got, no easy way to change that.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Donor: 1995 854 10V
