I've replaced my battery twice in the past 3 years due to it repeatedly going dead and having to be recharged so I decided to replace my positive battery cables. I'm going to get the B positive cable that goes to the fuse box from the dealer but I got this battery to starter cable:
http://www.fcpgroton.com/product-exec/p ... To+Starter
There is an additional thin cable that is screwed on to the top of the battery post connector and runs down inside the outer black cover of starter cable wire but this thin wire is not included with the replacement starter cable. What is the function of this wire? Should I replace it and does it come with the B+ cable or is it a separate part number?
Thanks,
Bill
96 850 positive battery cables question
- pkc303
- Year and Model: 1995 T-5R Yellow
- Been thanked: 3 times
Bill,
Have you found any battery better than another?
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
- pkc303
I replaced my battery under warranty with Sears. Seems ok. Disregard the previous post.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Perform a voltage drop test and then you will be 100% sure which cable you need to replace.
In my case...i needed to replace b+ cable which goes from positive battery terminal to starter.
Read this thread of mine:
https://www.matthewsvolvosite.com/forums ... =1&t=18694
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
williamregan
- Year and Model:
OK, since I already bought the positive battery to starter cable I want to install it and then see what happens. The starter end of the cable seems to be inaccessible. What stuff should I remove to get to it? I don't want to tear out more than is necessary.
Thanks,
Bill
Thanks,
Bill
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Just the fan shroud should do it. There are 2 bolts at the top holding it to the radiator/frame of the car, and then a bunch of plugs which are easy enough to sort out when you need to re-install it.
'98 S70 T5
2016 Chevy Cruze Premier
williamregan
- Year and Model:
I had a mechanic install the cable for me. My car seemed fine for awhile but then I had the same issue with the car not starting. I used a tester light and removed fuses one at a time to try to find out if I had a battery drain. I discovered the locking system was draining the battery so I left the fuse out and was ok again but then the same old no-start problem reoccurred. Took the car to my mechanic again and he diagnosed that the positive battery cable connector on the replacement cable was defective. He installed a new connector on the cable and my dead battery/non-start issue was solved. After a couple of months of trouble free driving I decided to reinstall the fuse for the central locking system. Sue enough, after a few days to non-start bugaboo returned. I took the fuse back out and was fine until the card died a year later. There probably was never anything wrong with my original battery cable.
